Show column header once at top and option to fix
When scrolling in views it would be nice that the headers can get fixed and only the rows are moving.
Comments: 3
05 Jan, '23
Thomas Lippert AdminHi Mathias,
This is a known limitation to our current UI framework. As a workaround you can configure to show the header every x lines.
We are currently evaluating options for replacing the framework. Your request is one of the requirements we have for the selection.
Best regards, Thomas -
06 Jan, '23
MathiasHi Thomas,
ah ok thanks! Yeah I had already the option "for every X lines" but the other option would be better. Then I wait for the new framework. -
09 Jan, '23
MathiasPS: The problem with "for every X lines" is also that it is not working when having "grouped by". Because then it is only for groups. So if I group by hosts to see all services (which are CRITICAL) under the related host then it won't change anything. But that makes the view not well-readable unfortunately.
