Cluster-IP for outgoing appliance traffic
4 votes
For incoming traffic to an appliance cluster you can use the cluster ip (e.g. traps), but for outgoing traffic the active node ip address is used. This is annoying for configuring ACLs and also for debugging. Some target devices only allow limited ip lists.
It would be great if also for outgoing site traffic the cluster ip is used, thus a cluster has a unified network behavior, regardless of the internal structure.
Under consideration Appliance Suggested by: Dennis Upvoted: 2 days ago Comments: 1
Comments: 1
