CRIT state when total memory is reduced
We have noticed that in some circumstances a completely broken server memory is not detected by management boards.
Sometimes they are simply gone.
The only indication is a reduced total amount of memory.
This should be flagged as critical, similar to changes in network interface speeds.
Comments: 2
02 May
Mohamed Saleh AdminHi René,
1
Thank you for posting on our Ideas Portal.
To make sure we fully understand your idea, it is about the ability to get a CRIT on the Memory service when the total memory goes down, as that would indicate a problem with the server memory? I adjusted the title of the idea to become a bit more descriptive, let me know if that is okay for you.
Warm regards,
Your Checkmk Team -
13 May
René BayerHi Mohamed,
yes that's absolutely right!
Thank you.
Best regards,
René
