Support AND, OR and NOT for labels in filters
Currently, a host needs to have all labels of a filter, so it is an AND operation.
It would be very helpful, if a OR operation can be used, so hosts of either of the defined labels are shown
Comments: 5
04 May
GerdWhile you are add it, could we get label filtering by regex?
11 May
Robert SanderOR operation is achieved by using two rules in the ruleset
12 May
AndyThis is for filters not rules. You can't add multiple filters for a view, for example
23 May
AndyIt would be nice if the labes, when used in filters or rules could be split by key:value and allows for wildcard/regex search.
For example you have one label key called city and the values contains a countrycode+city. So you could for example want to search for city:de to include all german sites. As this data (iirc) is stored in redis it would be possible to even show all the values that belongs to a specific key as dropdowns making the query faster. -
2 days ago
KGI like that. While you are at it, maybe that's too large but it would be sweet if all the fields/filters etc. would behave somehow the same and had the same rules applied. E.g. its not very intuitive that service-names do regex-matching by default while hostname-fields need a "~" prefix for that as they are exact match otherwise.
Maybe that needs to be another feature to vote for but that way this will all continue to look stitched together...
