Top 10 hosts dashlet
Allow to define a dashlet, which filters about some host information and shows only the top 10 hits from the results. This allows me as an admin to focus on specific servers (Example: top 10 by CPU, disk usage, memory consumption)
Comments: 1
11 May
fooEnhance it with AI! (we are in 2022)
Having the Top 10 by CPU or Memory is fine (better then nothing), but not always shows you the real critical ones.
For some Host its normal that they have high load at a certain time of the day/week (due to some regular job handling), one the simple approach this will leed to many false alarms in the dashboards/dashlets
This can be easily avoided by AI which is aware about it and only shows you the anomalies which are actually related to a problem
