Restrict site visibility for users to specific sites
Limit the visibility of sites for specific users
Comments: 3
02 Jun, '22
Robert SanderThis is already possible.
22 Jun, '22
CarloIf Distributed Monitoring is used, when a user filters, he will see all other sites, regardless of whether he has access to them or not.
For users created as global, it should be possible to restrict the "Site (enforced)" filter to specific sites. Similar to the filter "WATO Folder". This shows only folders with the contact group of the user. -
19 Jul, '22
Lars SörensenIt would also be very helpful if you could combine customers and sites in a access group and assign only one or more of these access groups to the user. This way you could easily adjust changes in the group without the need to adjust it individually for each user.
