Allow for disabling fetching specific NetApp information, like e.g. quota_info
Currently everything is fetched from the NetApp, which in our case, is so much info that it takes the plugin an hour to fetch (this specific NetApp is actually a cluster).
We ourselves have no interest in the quota_info, so we disabled this part in the plugin, which takes the total time it takes the plugin to fetch all data down to a single minute.
For obvious reasons this is not a recommended approach.
While it is possible to add all the Qtree services to "Disabled Services" (about a 1000 (one thousand) services in our case), the plugin still fetches all the information only to disregard it later on.
It would be great if there were an option to disable fetching specific information.
Comments: 1
18 Oct, '23
Mohamed Saleh AdminHello,
1
Thank you for your idea. On this portal, we carefully evaluate ideas to ensure that they will benefit a wide range of users. Thus, we close ideas not fulfilling certain criteria:
- Suggestions with low user interest: created more than 1 year ago with 5 votes or less
- Suggestions with no momentum: no votes in the last 6 months
Unfortunately, this suggestion doesn't meet these criteria, so we’re closing it (based on the data available until 2023-10-17). We appreciate your contribution and encourage you to continue to share your ideas. Your input plays a vital role in helping us improve our product for everyone.
Thank you for your understanding and continued support!
Warm regards,
Your Checkmk Team
