Create dynamic custom graphs using filters
Currently it's not possible to create dynamic graphs. If I'd like to have a graph showing interface bandwidth using host labels, for example I might have the vendor as a label (for example Cisco, juniper) and I like to have a dashboard having two graphs of CPU util for Cisco and Juniper.
Today I have to individually create these, or make a service search (with labels) and use the "all metrics of same type" shortcut. This will however still create a static chart.
I would like to be able to pick the hostname using host labels and perhaps the service using service labels (or static as the service would be the same on all hosts)
It would also be nice if the hostname host label does not have to be explicit set in the custom graph, but instead be set in the dashboard. This way I could have one custom graph in several dashboards, or the same custom graph in the same dashboard, but the labels would be set on the dashboard AND on the custom graph element in the dashboard.
Comments: 1
18 Oct, '23
Mohamed Saleh AdminHello,
Thank you for your idea. On this portal, we carefully evaluate ideas to ensure that they will benefit a wide range of users. Thus, we close ideas not fulfilling certain criteria:
- Suggestions with low user interest: created more than 1 year ago with 5 votes or less
- Suggestions with no momentum: no votes in the last 6 months
Unfortunately, this suggestion doesn't meet these criteria, so we’re closing it (based on the data available until 2023-10-17). We appreciate your contribution and encourage you to continue to share your ideas. Your input plays a vital role in helping us improve our product for everyone.
Thank you for your understanding and continued support!
Warm regards,
Your Checkmk Team
