Business intelligence: Removing of Rules with dependencies
When deleting BI Rules, you have to delete the top level rule first, then the lower hierarchy rules.
If you have a lot of "verschachtelte" rules then this is a messy work :-)
As well if you mark both rules (top and lower hierarchy ones) the deletion of those does not work at all.
I would like to mark all rules (with dependencies) and delete them in one click.
It would be even okay if the system checks if the rule marked for deletion is dependent on another, and if the other rule is also marked for deletion - then delete them both.
Otherwise, just delete the top rule and push an information.
Comments: 1
18 Oct, '23
Mohamed Saleh AdminHello,
Thank you for your idea. On this portal, we carefully evaluate ideas to ensure that they will benefit a wide range of users. Thus, we close ideas not fulfilling certain criteria:
- Suggestions with low user interest: created more than 1 year ago with 5 votes or less
- Suggestions with no momentum: no votes in the last 6 months
Unfortunately, this suggestion doesn't meet these criteria, so we’re closing it (based on the data available until 2023-10-17). We appreciate your contribution and encourage you to continue to share your ideas. Your input plays a vital role in helping us improve our product for everyone.
Thank you for your understanding and continued support!
Warm regards,
Your Checkmk Team
