Extend fileinfo/mk_filestats feature set to monitor directory/file permissions
While the current fileinfo and mk_filestats implementation allows way more options we actually need, we are missing one feature that could (hopefully) be easily added: Monitoring permission settings for directories/files.
Our need raises from application hosts that are accessed by multiple persons/roles and configuration files that contain confidential information (e.g. username/password for accessing backend services). We would like to use this feature to ensure that we get informed if a deployment process or application administrator changes the file permissions by accident.
Comments: 2
18 Oct, '23
Martin Hirschvogel AdminHello,
Thank you for your idea. On this portal, we carefully evaluate ideas to ensure that they will benefit a wide range of users. Thus, we close ideas not fulfilling certain criteria:
- Suggestions with low user interest: created more than 1 year ago with 5 votes or less
- Suggestions with no momentum: no votes in the last 6 months
Unfortunately, this suggestion doesn't meet these criteria, so we’re closing it (based on the data available until 2023-10-17). We appreciate your contribution and encourage you to continue to share your ideas. Your input plays a vital role in helping us improve our product for everyone.
Thank you for your understanding and continued support!
Warm regards,
Your Checkmk Team -
18 Oct, '23
Martin Hirschvogel AdminException: We actually decided to keep this under consideration as it received quite a lot of upvotes, is a sensible feature and was created in 2023.
