Juniper Virtual Chassis Plugin
There does not appear to be any support for monitoring a cluster of juniper switches configured as a single virtual switch (virtual chassis in Juniper terms OR switch stack in Cisco terms).
Comments: 3
24 Aug
Niklas Pulina AdminHi HYU, thanks a lot for your suggestion.
Depending on your specific use case, the chapter about cluster monitoring in our documentation might be helpful for you: https://docs.checkmk.com/latest/en/clustered_services.html
Also, you can find an overview of our Juniper plugins at https://checkmk.com/integrations?distributions%5B%5D=check_mk&distributions%5B%5D=check_mk_cloud&search=juniper
Apart from that, there's a Nagios plugin which might be worth having a look at:
https://github.com/epiecs/nagios-check-plugin-juniper-virtual-chassis
I hope to have helped you with this. If not, please don't hesitate to share more details about your use case. This helps us understand your requirements. Thank you! -
28 Aug
AndyWe also have that problem, my understand was that that the feature request portal was to be used to request feature requests, not get links how to solve it in another way, like the nagios link. Not very useful.
The demand is clear, juniper have support for logically combine several physical switches or routes into one virtual, meaning that SNMP traffic will hit one of the members who is acting as the master, but we are missing the information related to the state of the virtual chassis. This is essential for that kind of monitoring. -
29 Aug
Niklas Pulina AdminHi Andy, thank you for your comment and for specifying the use case even further.
You're absolutely right, the purpose of our Feature Portal is to collect and prioritize our users' feature requests. For this reason, we have set this suggestion to "Under consideration" status. However, many users appreciate having a short-term interim solution for their problem suggested which helps them bridge the time until their request might be implemented.
