Reporting: Set RRD consolidation and Aggregation function in metrics graph
In the reporting element "Metrics graph of a single service", there is no possibility to set neither the RRD consolidation nor the aggregation function. It would be useful to customize this setting per graph, like it is possible in the GUI.
Today, this is possible in only a few select elements.
Comments: 2
02 Oct, '23
Martin Hirschvogel AdminAre you talking about the dashlets "Single metric graph", "Perfomance graph" and "Combined graph"?
They by default take the "Maximum" value stored for historic metrics in the RRD. And you would like to configure, e.g. Minimum or Average instead of Maximum? -
18 Oct, '23
Marcel Arentz AdminAs far as I understand, you're referring to a typical graph, where you may switch the consolidation function (=the data column in a RRD file to use when displaying a metric) and then select the aggregations that should be display in the legend of the graph additional to "last".
In the report element ""Metrics graph of a single service" you want to be able to use these two options.
Is this correct?
