Create Metrics via BI Host-Search Filter + HW/SW as filter criteria
The idea is to use a host-search filter to search for specific hosts regarding their attributes instead of a specific hostname.
Example: I want all hosts with a specific serial-number to collect service metrics into one graph.
In addition it would be useful to filter for their HW-/SW-Inventory attributes instead of check_mk parameters. This implies a working HW/SW Inventory of course, but using these then as an addition filter.
Comments: 1
08 Nov, '23
Kevin EßerThe idea is, that you can create metrics like you can create BI-Rules based on search-filter, which then creates sub-nodes based on the filtered criteria.
